Speed Wobbles, pulling left.
I've been to a couple of mechanics and also Pedders to solve a problem. Wanting to fix the car up all nice in case someone wants to buy.. but even if I keep it, I want it fixed!
Car was tracking beautifully and then I went 4WD'ing last year. Now it's pulling left a bit and has the patrol steering wheel wobbles.
Pedders report says the following;
Leading Arm bushes - Bushes Torn, requires replacement x1
Panhard Rod - Excessive movement x1
Engine Mounts - Need replacing (getting done next week)
Wheel bearings - Bearing play and ball pivots x2
Trailing arms - bushes torn require replacement
Panhard Rod - Bushes soft, recommend replacement
Now, I've had 2 mechanics check through this. Both said, don't worry about the ball pivots. There is only a very slight movement in them and it's not going to give you symtoms of your current problems.
Wheel bearings, slight movement.
Trailing arm, def replace the bushes. Do both, not just one.
What I want to know is, what parts are specifically involved in the car tracking straight and or causing wheel wobbles?
I know the wheel bearings can cause wheel wobbles and I also know the wheel weights on the wheels can cause some wobbles. But as for the rest of it, I can't see how it would cause the car to pull left and shake the wheel at around 80km's.
Any advice appreciated.
Did you have wheel wobbles? Car pulling to the left or right? What was the actual reason??
ps. Pedders bill was over $2,000.
