2 Attachment(s)
PATROL ELECTRICAL GREMILIN'S....dont feed 'em after midnight
Ahh the joys!.... Has anyone had this happen to there patrol or know of this happening or how to fix this problem??: 3 out of 4 of the the dash gauges (oil press,temp and fuel) are waving around (registering for a sec then die) at idle then when you get out on the road they just die ive had the dash apart, the cluster apart traced wire's back and found nothing????? Just wondering if anyone's come across this before and how to rectify it as in attached pics you can see i hav'nt moved the vehicle and they just go out just like ive cut the power ive gone over everything i can think of but to no avail!..... Im thinking dry solder joint in cluster plugs, exessive water in cabin area, stuffed cluster but i am not sure any info/help would be greatly appreciated thank you,
8 Attachment(s)
"86 PATROL DASH ELECTRICAL GREMLINS dont feed 'em past midnite and never get 'em wet
These pics are taken at: 1.IGN OFF, 2.IGN ON, 3. STARTUP, 4. REVERSING OUT, 5.TAKING OFF IN 1st, 6. DRIVING 60-80kph, 7. DRIVING 100kph. I have a multimeterbut dont know enough about it to work it properly for what i want to check.. The volt meter works fine and i dont have to have oil press or water temp as i can get them aftermarket its just the fuel gauge i liked to have working cause as we all know you dont let a DIESEL run out of fuel and also there is no dimming of lights as asked earlier, This problem happened once before and the gauges did'nt work for 6-10months and i took 'er to the snow and got bogged in 4wd in a snow storm and left a Qtr vent window open and as the snow melted the dash came back to life but that was 3yrs ago and have worked fine since any tips on using a multimeter would be a great help also thanks for your feedback....MS
5 Attachment(s)
Why mq-mk dash clusters short out and dont work
Thankyou to everyone that tried to point me in the right direction on this topic over the last week or so
Well here's the problem.... 3/4 small cluster gauges (oil press, water temp, fuel) were not reading accuratly they were fluctuating and therefore not giving any true readings.
The volt meter was still fine, I had the dash/cluster apart several times in the last 2-3 weeks checking for dry solder joints broken wires etc... found nothing.. sprayed contact cleaner in anything i could find it worked for 35- 40 mins then.... nothing.... so by now i was thinking the sender's must be stuffed from mud water etc (i had been shooting and mud bashing a fair bit recently) so i was thinking of buying after market mechanical gauges to solve it.... good idea but then i still have no diesel gauge and you want one of them to prevent having to bleed 'em when they catch you out with no fuel.... by this stage i was not happy and lost on what to do...
Then an old mate came 'round, and asked to have a look at the cluster pulled it apart and(for the 4th time in 6 day's) and after 'bout 40sec's he say's "Well There's Ya Problem Mikey".....I did'nt see 'em earlyer but there are little wire's behind the gauges that look like metal fishing line and they were all tangled which arc'ed out shorting 'em out and killing them... they then become throw away items....Great! so i went looking 'round wreakers and got one got it home only to find that the tacho and speedo did'nt work.... ha ha just my luck.. but after root'n around with cluster bit's all day i've finaly made 1 cluster out of 2 and along with an l.e.d. upgrade it works perfectly.... bit of a long story i know.... but its been a long day.
thanks to everyone for there help on this subject...
And a big thanks to cale from cale's mobile auto electrical for finding out what exactly was wrong..thanks old mate!.... Mike
