How do I remove dash switches in 2012 GU
Hi all,
Over the last few weeks, I've been doing a few electrical mods. I want to get to the back of the instrument light dimmer to connect the backlighting in my boost and pyro guages. Seem to remember in my '99 GU II that the switches just popped out the front of the dash but I can't seem to get them out this way in the new one. I can't see properly, but it is almost like they are screwed in from the rear and then the dash was assembled. Any clues?
Thanks Yendor-Dimmer Control
Quote:
Yendor
Yes they are screwed in. If you put your hand up from under you should be able to disconnect the plug from the back of the dimmer switch and get access to the wires.
If you want you gauge lights to dim with the dimmer switch, connect then across the blue with a black trace wire and pink wire.
If you want them to come on full brightness regardless of dimmer switch position, connect them across the blue with a black trace wire and black wire.
Yendor, your post dates back a bit but did it for me. Have been seeking advice for 3xVDO gauges hook up to utilize dimmer (variation) illumination control. Did some more goggling and found your post. Worked well Thanks heaps and will connect the three gauge globes up in parallel.
