Whining gearbox/ 1,2,3 and 5th
Quote:
mackayboi
Hi,
I just done a simple oil change and now I have really stuffed things up.
I was reading online that over filling the oil actually damages the engine.
As I don't have a GQ Patrol manual readily available, could someone please tell me how much engine oil is needed? (6 cylinder, 4.2 Litre Diesel) from a GQ 1990 Patrol.
I really cant believe how a simple oil change, after all the other things I modified on my vehicle, is the one to get it undone.
I put in 9 litres of oil yesterday. and today I went to drain the engine oil, and nothing comes out! I mean it was not leaking oil from the 20km I driven. and it wasn't burning it up because there was no black smoke from exhaust.
I needed to drain engine oil out due to a whining sound that came from the 1,2,3 and 5th gear when driving. Furthermore, at about 1100 RPM the engine shakes just noticeably.
I feared that the problem was over dosed in the oil, but now there is none to be coming out of the bottom bung.
Thanks for any help...
Hi
I have just bought a GQ with a RD28T engine and I have not owned a Patrol before.....I noted with interest that your car was making a whining sound in 1, 2,3 and 5th gear under acceleration (4th is very very quiet ) and wondered if you had determined what might / was the problem?? Where you able to reduce or eliminate the noise ??
Thanks for any assistance Ian
whining noise in 1,2,3,and 5th
Hi I just bought my first GQ patrol (in great nick overall and very well maintained) and so I am new to the forum ....there is an annoying whining noise in 1, 2, 3 and 5th gear when under accelaration. 4th gear is incredibly quiet. I noted this was mentioned up above in an earlier post. Does anyone have any technical ideas on how to minimise or eliminate the noise. The gearbox was a second hand one put in just 20,000 km ago and the previous owner of 12 years said that the noise was there when he put it in and it hasn't got any worse? Why would 4th be quiet and the others noisy??
Regards Ian
