Head or Block
Just another dumb blonde question. The housemate has literally pulled apart the motor after my mishap. Was hoping to get away with just the oil cooler (the rings and gasket were shot) ... Welshplug behind the cooler was rusted out, and another at the back of the head. Fixed all that. Dropped the sump, and after a 'test' found water was still leaking somewhere around cylinder 5. Replaced head gasket & manifold gasket ?? .... (and a missing bolt from god knows how many years ago) (Oh, and found some socket thing he lost in the area of the motor most probably the same time) ..... so pretty much put it all back together and its still leaking water from around the same area. Assuming its not the head, as he cleaned it and didn't see any cracks. So, its gotta be the block huh, if so, is there an easy way to confirm that ?? Or is there something he has missed maybe ?? Apparently the water is running out (under no pressure), not just dripping.
Please remember, my housemate sorta knows what he is doing, but I have no idea. All I am trying to do it get a gist of things, so I know what he is talking about (I am learning lots of new words tho) ...
Any help would be greatly appreciated from where to go from now ..
Jenn
Hey jenn,
Sorry what motor is it mate? Zd30? Have you got any pics of the water coming out? Is the engine running yet?
The head might be warped. Put a steel ruler against it to check.......
SD33T 1987 MQ Mudrunner ..... haven't got pics as yet ...
its an old motor NP99, so its not an aluminium head if that's what you mean ??
I suppose what I am really asking is has he missed anything when he had the motor pulled apart ????? Big question I know. Sigh :(
The head looked nothing like that unfortunately NP... and after he took it off, he cleaned it up and found no cracks ...
Will show him in the morning ... it might make sense to him ...thankyou ???
a good handy man has a very good gopher for this type of work
as he throughs the tools to the other side of the shed in frustration you as the gopher need to retrieve them and hand them back for another round
That person goes by the name of Gilligan in our family :)
You could pour in some Chemiweld to seal any cracks permenantely.
Not my cup of tea, but a cheap way to seal cracks
Hey Fruitloop, re your SD33T, if the motor was turned over, even by hand when the head was off, there is a chance that the cylinder liner has moved, they rely on a tiny seal at the bottom of the liner and this is probably where the water is coming from.
The cylinder liner is surrounded by water and if the seals are disturbed, they will leak.
The head needs to come off again and all new seals fitted to the cylinders.
Other than that, the block could be cracked.
Did you have the head crack tested?
You should be able to re use the new rings, making sure the pistons go back in their original hole.
You will also need a NEW head gasket.
You could remove the head and fill the block with water and see if it's still leaking, this would give you a better idea of where the problem is.
This is my opinion.
Cheers, the ferret.
EDIT.. Further investigation tells me your motor may be the "dry liner" type, so the problem may not be the liner seals after all.
Good point Ferret, the head should be checked by a specialist, rather than by eye.
hahaha mythird, I am definitely the gopher .... I was in the shed yesterday and He was looking for something .. all I heard was 'now where did I throw that ???'
@ 3dogs : He bought some chemiweld today as a last resort ..
@ Ferrett : He did a 'visual' on the head and could 'see' no crack .... getting him to have it properly looked at, would be like me trying to convince him he HAD to go with the Paramedics when he had his stroke lol.
Anyway, He has determined the block is not losing water; it seems to be leaking down to the head gasket level. Speaking of liners, He was talking to someone today who had just worked on a similar case with a similar model. This guy said he was surprised to find the head gasket bolts had liners. When he further investigated (on the car he was working on at the time), two of them had rusted. Once replaced, problem fixed.
The saga continues lol. Thanks again for all your input and help.
@ fruitloop, chemiweld is like a bandaid on sore thumb, it only washes off.
Get the head crack tested, use new head studs, check liner protrusion before fitting the head.
This way, you may have a longer period of time before the next stroke lol.
You can end up doing the job a dozen times if you don't eliminate all possibilities, eliminate the obvious my girl.
Cheers, the ferret
Happy to say he has decided to remove the head once again, and I Am HOPING he will get it checked properly
1 Attachment(s)
Found this in the shed ... This is what I have to deal with lol ...
Hmmmmmm, that's a worry lol.
Cheers the ferret.
He chose the chemiweld option .... I don't know much, but after everything I have read on here, I know its not the best option. We took it out for a wee drive today ... seemed fine. I just don't know what to say anymore. So ... having said that .. I spose my time here is done :( You guys have been great. Thankyou so much ...
Yalll come back now, y'hear?
Cheers, the ferret
