towing a heavy laiden offroad van, cruising down the highway at 100 clicks, egt around 440 degrees, however, since summer is coming along up in central QLD where we are around the 36-38 degree mark. After being on the road for only about an hour the temps are climbing above normal even when slowing down to 95klms and a gear down, they still do not go down. Vehicle has only done 100,000klms. All NADS done.
The only 2 things I can come up with is
1. heat soak in the intercooler ?, and I don't think that is it as it is a new aftermarket ic
2. Standard radiator can not handle the higher summer temps?
Have checked the viscous hub, coolant changed every 2 years
Has anyone put one of these PWR radiators in ? and did it change the temps ?
# please note it is an Auto with a lock up switch and a heavy duty valve body
