Ok .....so im in need of extra power from my standard 3.0 litre diesel turbo automatic.
question 1/ Best option for extra power. ( towing 1.2 tonne trailer to NT )
Question 2/ Is it possible to install 4.2 litre diesel in my vehicle ?
thanks
Tony
thanks
Tony
Hey Tony,
Alot of people do the TD42 conversion, its just more finding a complete motor at the right price,
Diesel chip in the zd30 gives some power, but be sure to have NADS fitted.
Rob,
Chip, exhaust, and NADS and possibly custom intercooler will make it quicker. Mines got decent power now without a load ill be good to see what it's like when we buy a van.
Tony,
Just installing a 4.2 wont give you more power, and towing 1.2 tonne with the 3 Litre is a doddle.
As others have said, chip and exhaust will give you good driveability gains.
I have had just a chip for years, on the early DI's and that was great, I have had CRD's with and without exhaust done, and they have been great.
Everyone says the combination of both will give you really good gains, but I can't speak from experience ..... yet.
Mic
Also I've just purchased my first patrol (haven't even got the keys yet) and wanted some opinions on what mods to do on a stoke 3ltr turbo diesel, 2010 , auto wagon
Hi . thanks
I have a 2003 Nissan gu 3.0 litre.
there is a catch can, boost and turbo timer............Im thinking that someone has already done a DET kit install.
Just out of curiosity where would a DP steinbaur chip located if installed. ?
Tony
What about a turbo timer? Does anyone think it's a good idea?
Waz
Waste of time. You can do the same by not turning off before you have collected wallet, thongs and got out of the seat.
As part of NADs people often fit a temperature guage (pyrometer) with the probe situated just after the manifold to measure exhaust gas temperature (EGTs).
A more correct method to guage shut off time would be a temperature on the egt guage below which signifies the engine is cool enough. 200 degrees Celsius is a general figure.
The egt guage gives a good understanding on what causes high eg temperatures. Highway driving will need a little extra time to idle and cool down. Hitting your nominal maximum egt temp? Modify your driving. Subtle changes in your driving habits will allow lower egts and hopefully save your engine.
Dawes valve catch?
Sorry missed this before and not quite understanding what is does
Dawes valve is a 'safety valve' to manually limit boost.
Catch can is to remove oily vapours from the air being fed from inside the engine back to the intake.
There is a document somewhere from either this forum or the other one. It does a better job at explaining it all. You can skip the boring bits and pick it back up when the interest takes you there. It isn't the service manual. It compliments it.
Does anyone have the link?
We have towed a heavy camper trailer to Birdsville, Queensland central coast etc, Also done quite a bit on tough farm roads with plenty of steep crossings and hills with camper in tow.
We have never been short on power, although we do need plenty of space if overtaking.
Only mod is an exhaust system. I suspect NADS would be good, and chips certainly add kw.
