Hi all.
Im really over the boost gaugue rattle in my GU. I've tryed putting a damper in the vac line which helped but its still there. The question is what gauge do i get that is deffinitly not going to rattle and wont break my bank.
Cheers Ryan
Hi all.
Cheers Ryan
Howdy I have a auto meter Cabot it's been installed for about 18mths and has not missed a beat would recommend them def no noise .... I was told the noise was from a leak but not sure ... My hose from intercooler pipe to gauge is the small hard plastic type ...
I have boost and oil on the right hand side of the instrument cluster, the gauges are kn pods and the are velcroed to the dash, together and to the a pillar, havent moved in 3 years
Buy a digital one then it won't rattle :D
Hey that's true didn't think of a digital one that's and idea. Any one using VDO ? A mate of mine had one seems to good. My gauge isn't designed for the diesel motor that's y I'm getting the rattle and Major bouncing of the needle at idle...
I take it that it's a mechanical gauge with a hose from the engine? If that's the case then the hose acts like a stethoscope and the gauge just amplifies the noise in the cabin. It's worse when using copper hose, but apparently putting a loop in the hose before it enters the cabin can help.
Yeahhh mech gauge plastic line. Yeah did read that while searching google. I dont think I've left enough hose though ill go buy rubber line tomorrow or might just get a auto meter gauge for diesel boost
If you're on a budget like me I bought a digital boost gauge from repco when they had the sale $39, it's for a petrol but that doesn't matter to me as it just sits on 0 when not on boost....
Cheers,
Eric.
Cheers trekster ill check that out tomorrow are they 52mm?
Yeah mate and they are on special again!
http://catalogues.repco.com.au/offer...urce=catalogue
They come with their own map sensor and you just hook it all up and away you go!
Ohh awsome thanks for that bud
Also, See this thread for some pics of my gauge
http://www.nissanpatrol.com.au/forum...ke-to-stick-it
cheers,
Eric.
I have heard that digital gauges flicker, That's why I don't have them
Just thought id let you know i managed to stop the rattle/vibration but stuffing some foam in the damper just before the gauge it now A1. For the future though id just recommend an electric gauge alot less mucking around :smiley_thumbs_up:
I needed an extra 2 vac lines over the available std fittings.
So drill an extra 1/8 post no problem.
turns out, lower in the manifold is more susceptible to fluctuation in vacum.
seems I found a spot that has poor constant vacum
My vac gauge started to rattle as you guys are describing.
It may just pay to try a different hook up point.
You might solve the unwanted rattle.
