Calling advise?? New zd30 create motor or td42t conversion
Hi all! I've recently purchased a 2001 gu zd30 auto bought it back in January had a full engine rebuild and new injector pump rebuild too, 20,000ks ago! It went kaboomm four weeks ago! I serviced it and didn't flog it either! Went up with a bang and a cloud of white smoke! Had full nads and egt was 350 got major blow buy out of catch can and out of dipstick too! So I'm considering it stuffed! My next thoughts are td42t but I've been researching and it's doable but won't be cheap! Car will be off the road for some time, I can do a lot of work myself! Probably all of it, but I think it will still cost $10,000 or more? Or I can get brand new zd30 crate motor $5995 rebuild turbo? The motor is from ftgully nissan they say that they are the latest spec zd30 available and built 2012? Any thoughts on what I should do? Would the zd30 be past it's problems if nissan are supply them for replacement? I'm not sure if I should trust one again, but it would be alot cheaper and less labour than fitting a td42t
Cheers for any thoughts
A great bunch of people here with lots of experience with these beasts!
