Hi All
I have been around this forum doing R&D for a SAS -however plan changed - Anyhow, I started 4by in a D22 Nav - bought stock and modded it until I realized that IFS will not suit to my liking. So sold the Navara last weekend
which I bought the GU last weekend 20th of July 2013 - it is stock apart from DPCHIP, DVD player, Roof Rack/Roof basket/ UHF 40 channel.
After buying the GU - it was a bit Smokey - so straight away done a lot of research and found possible solutions - so last Sunday we've done a good service - all fluid flushed and changed - all filters changed - straight away improved the smoking - however I will also do a oil catch can /MAF change and EGR Block.
Today we completed the Suspension setup - 3" lift Kit Ultima shocks and King Springs, Gab Steering Damper and Tough Dog Front and Rear Panhards - 15x8 -22 White Steel wheels and 33" M/T bighorns, extended brake lines, finally caster bushes changed.
So so far I have - car is serviced and mods are
Diesel Chip - DP Chip
3" exhaust - Liverpool Exhaust with EGR Blocked
Mud Tyres 35" x 5 - 4 Maxxis Bighorns and 1 Mudstar - near new
15x10 -22 Sunnies
Silicone Intercooler Hoses
Aftermarket Intercooler
Steel Winch Bar- genuine Nissan
Fishing Rod Holder
12000 lbs Hercules Winch
UHF Radio 40 Channel with Aerial - Uniden
Kenwood single din with Roof 10" DVD
Snorkel - Tigerz11
3" lift w/30mm spacer & CASTER Correction Bushes - 4" Ultima Shocks
Extended Diff Breathers
Extended Brake Lines Tough Dog
Steering Damper - Ultima
Front and Rear Adjustable Panhard - Tough Dog
Dual Battery Tray - ARB not installed yet
Cargo Barrier - Genuine Nissan
Radiator Hose and Belt - New from Road Runner
Toolbox - Rhino
Roof Rack ARB 3/4
Side Awning
Hi Lift and Shovel Holder - Roo System
9" driving light - Calibre Raptors
IPF Roof Rack Light LED lights
Air Compressor
MAF - Genuine Nissan
Boost Gauge
Gauge holder
Thermostat and Water pump - Road Runner
New PAds and Rotors all around
High Lift Jack & complete recovery Gears
My plan is to make this GU track and touring friendly - so next mods are
Rock Sliders
Rear wheel carrier
Front e-Locker
Photos attached
