Great Southern Camping
Dumb question - are you using water (check radiator and overflow) and water out of exhaust under power whilst stationary.
If the diaphragm in the converter goes it will mix with water from your cooling system depending on the model/setup. This will not only see you run your cooling system dry and cause potential havoc, but will see dramatic decline in LPG power and/or performance.
May not be, but identified the issue and fixed one last year for another member that had this very problem.
