First mechanical(?) problem in 17 years.......
Hi Guys,
I've owned my GQ Y60 manual 4.2 EFI Petrol (203,000km) from new and for the first time, I have a problem.
It has been misfiring (idling rough) and was advised by the mechanic to run it on premium with Nulon injector cleaner which I did on a trip I have just completed (2,000km).......no change.
I was then advised to have the tappets adjusted which I had done today.....it's now idling worse than before!
I am going to have a compression test done next (subject to the feedback I get from here on the forum).
I recently had a new dist. cap, rotor,leads and plugs fitted.......it was running fine before this ( could it be a faulty plug ?)........I'm a bit doubtful about the latter because it would idle normally and then the next time I started it up it was rough and so on.
I had a major service done at 200,000.......when the trouble seemed to start.
HELP AND / OR ADVICE TRULY APPRECIATED.
