I want to fit longer sway bars that are adjustable and wanted to know if there is any exception for having sway bar disconnect....?
Someone planted a seed and said I would only need 3 as I have the disconnect model?
Advice please.....
Advice please.....
Anyone???? need to know as Irish is picking them up for me from Bayswater?
Your question has lost me..
You want to fit longer adjustable links to the sway bar?
Cool, just buy them.
Although if you have the disconnect you will need to get an extension kit for that to or the other side will be always fighting it... Boarder track engineering do complete kits for the extension to bring sway bars back to level..
Owner of
Westy's Accessories
May not be the safest option but as you know BA I have removed my front sway bar and having the 2" GU lift (2 1/2 to 3" real lift) enables me to keep the rear disconnect and I love it. "Safe" on the road for me and manual disconnect offroad.
So is it really only the fronts I need???
That would all I would bother with. You don't drive fast enough to need sway bars anyway :p
I would get 3 and if you have to modify the disconnect.
Well if you're doing the front, may as well do the rears.............
So can we give you the sh*ts again now????? ;)
Tappin on the MC phone
As I said BA, if you wanna do both you either need to remove the disconnect unit and install a threaded eye like the other 3 or get the extension kit..
Owner of
Westy's Accessories
Why not get all 4 a make one fit into the factory disconnect unit
Not sure if that will work as the disconnect is shaft, not thread..
The bloke a BTE has made these kits so it extends the travel length of the disconnect, so your sway bar has less resistance for a greater length..
Owner of
Westy's Accessories
Cheers guys........ so for the sake of this weekend I should install 3 of them and while 4wding just disconnect the 4th for the day???? then get the 4th one sorted later?????
Do them all at a later day. The disconnect will need to be extended. You could do the just front for your trip but you can't just extend one link on the rear.
There are people who make something to allow the disconnect to work better while also extending it. Westy mentions it in post #12
Yes but I dont know who he is talking about?? BTE???
Border track engineering
Try superior they do them
Just spoke to a bloke who said they put the normal set up in them and do away with the disconnect????
Jonathan just fit the fronts we'll remove the rear until you sort it out, you wont feel the back as much as the front.
JUst ordered a plate from superior engineering to do away with the disconnect.. should be here tomorrow??
How bloody fast are you going round corners?? All it will do is try and step out IMO
Not fast at all you can feel the difference
Hey George,
actually i think the opposite is true mate.
I run no sway bar on the back of the GQ and disconnects on the front and No sway bar on the front of the GUIV and factory sway bar on the rear.
I am currently chasing a GU sway bar for the rear of the GQ for permanent fix and will remove the front. My GUIV is so much more comfortable to ride in with the back connected and the front is pointless.
Most of the flex is a Patrol is in the back, plenty of guys spend BIG BUCKS trying to get the front to flex and they fail. Sway bar is nowhere near as important of the front of a Patrol. back is where its at. IMO
My2c
My GQ has the factory rear disconnect (albeit stretched from the lift). I can definitely feel it if I forget to reconnect when back on half a road. I also like to have a play on faster gravel sections and she gets A LOT looser without the rear connected lol
sent from my phone using motor culture
I feel your pain. They got me for no front sway bar a few weeks ago, not even a km from my house. No defect, just a fine.
As said, disconnects for the front, leave the rear. I have found, that the front still doesnt move as much as i would like with the sway bar still bolted to the radius arms. If you want some sort of front end movement, lose the sway bar all together. The disconnects do help though, only slightly.
Damn Scotty!!
I missed that post! That sux big time mate. In Vic you would have to get the whole car Engineered as a Unit. Then additions added to the compliance i think?? Guessing ;)
If i was to do that i think id put a cage in her first ;)
are you back on the road yet? It was all shiny and stuff too!!
I think i'm thinking if how a car reacts without swaybars and not taking into account where talking 4wd's. my understanding is the swaybars help put the weight back onto the wheel thats closest to the corner ( inside wheel) for eg you turn right, the body leans to the left making the inside/right hand wheels try and lift off the ground coz the weight has shifted, the sway bar connected to the outside / left hand suspension twists down pushing the inside wheel back down. On a car you would add a strut brace to help counter the affects of the body roll but off rd you want the wheels to travel further up or down to try and keep the body level as possible while keeping maximum traction on the wheels at different heights, yeh??
Hope i made sense of did i just confuse the situation lol??
Who needs sway bars anyway, if it wasn't for legalities I wouldn't have em on.................oh hang on a sec I don't have them on :):):)
Ok, hopefully this works. Boadertrack details to come ba
Owner of
Westy's Accessories
It didn't.. mc crap a lot keeps dumping my post in the night shift thread.. stupid app... :banghead:
Owner of
Westy's Accessories
Dave
Boadertrack 4x4 and fabrication
0400250734
Finally.. give him a call mate. Pretty sure he has the kits on self as a DIY job.
Owner of
Westy's Accessories
Cheers Kallen but for now I am just going to go with long bars and do away with the disconnect.. may change later ??
Should the sway bar be level when flat on the ground????
The sway bar should be at 90 degrees to the threaded rod.. so yes, level with the ground..
Give or take a bit though..
Owner of
Westy's Accessories
That was a good read GSC. Though does annoy me when it comes to all the red tape side of things.
I remember when I first got my licence, I got pulled over in my old landy. The cop started inspecting under the guards, walked around it, had no idea what he was looking at so he just walked off. Certainly didn't have a shock absorbing steering wheel, or dash, yet that law doesn't apply to this car because of the age it was made. Could legally drive it. It does my head in with how they can justify things.
