I'm chasing a diff breather kit. with breathers and hose, mounts fittings etc to extend gbox, diffs etc on both a gq patrol and a suzuki jimny if any one has a decent priced kit.
You can make your own with a bit of fuel line and a couple if real cheap fuel filters.
FanTapstic!
I just used these , mainly the rear as front on GU already done,
If you want to buy a set you can get them on eBay around $60 they do look neater than a home made job
Decided that as i have nowhere but under the bonnet to mount any of those kits, and thats not high enough, im simply ditching the wank factor and running the breathers into the cab and up the inside of the a pillar. No stupid filters or mounts required. A hundred bucks for some hose, bit of bent steel and some fish tank bubblers with some zip ties was a bit of a waste of coin.
Yep I agree, those kits are totally over priced.
FanTapstic!
Yeah, im not using fuel hose tho dude, vacuum hose is cheaper but i found that hose they use, 10 bucks for 20 meters. Breathers in an aquarium shop for a few bucks. So i saved myself enough to shout a celebratory carton
Woohoo! Celebratory carton:-).
Just make sure the breather line material is compatible with oil
FanTapstic!
Good Vacuum hose usualy is dude. All sweet
If you're running it up the inside on the "A" pillar Jaycar sell
sticky backed Square pads that except a small cable tie.
Would make the job neat too. come in black or white.
Its under neath the interior so it holds itself up and you cant see it, good idea though dude
