Hi need torque settings for injector hold down bolt 12ml for a zd30 gu 3
cheers
cheers
I can't find any torque settings in Ellery manual
does anyone know if 120lbs sounds correct
Re read the whole article no reference whats so ever, Sorry bout that
Hi what size is the bolt/stud??
If its an 8mm bolt /stud it should be 27nm or 20ftlbs
95nm 70ftlbs going by my specs on bolts
95nm. 70ftlbs
Ive got a book that i have used since i was an apprentice that has all bolt specs etc i dont rely on manufactures specs as ive found that sometimes the bolts/studs will stretch or damage the threads so all motors pumps etc that i rebuild i use the book for all the bolt tensions & have never had any failers
Hi guys. I have a 2003 GUIII / Y61, 3L, 4CYL, manual, turbo diesel Patrol. Would anyone here know the 5 step torque settings for my harmonic balancer? Needs replacing.. Cheers
