Help me weld pleeeeessssssssseeee
I've borrowed a mig from Geeza (my toymota drivin mate some of you met at loveday) He was a panel beater in the UK. He bought his welder out with him and tells me its a beauty (i would have NFI but he is a pedantic fussy so n so) Now it hasnt been used for 16 years but all the functions seem operable. Except i cant get it to bloody weld properly. Ive done a bit of welding in the past so am not a total moron when it comes to the art, but ive never had to set one up from scratch. Geezas away so cant get him to help. Ive adjusted amperage wire speed gas flow and nothing bloody works its doin my head in. I wanna weld patches into my Torana where ive cut the rust out but am getting frock all penetration. Am getting blobs of sh!t Pics below are the welder and what the weld looks like that im getting
http://i1189.photobucket.com/albums/...792F275F54.jpg
http://i1189.photobucket.com/albums/...7941B04F5E.jpg
http://i1189.photobucket.com/albums/...79541ED728.jpg
http://i1189.photobucket.com/albums/...79618EF0E2.jpg
So any help for wire speed, amperage setting, gas flow will be great cheers.
1 Attachment(s)
Do help with the bog or welding ??
The bog you should try and keep it to a shape like a circle or square so you don't have a ton of shrink marks in the paint! Something like this
Attachment 27400
The black stuff is rust converter
Does this welder have a high and low?? Gas flow should be 14 lps while the trigger pressed IMO and on setting number 2 wire speed should be between 3 - 4, when your mig welding ( if your right handed) start to the most furthest part then weld towards your face so you can see where your going when you do a long fillet.
Its not hard just need to learn the welder and if your blowing holes its either the wire speed is too slow or the amp setting is too high
Quote:
growler2058
I was told not to try and weld the whole piece in 1 hit and to spot weld the whole lot systematically
Yeh thats right, i've done spots "systematically" before and it makes the weld look like chicken shite!!! You can also put you spots in 15mm apart with low wire speed then turn it up a bit and fill the gaps moving around the piece to keep an even heat. I use tig now alot cleaner and i've got it nearly down pat so a light grind with a flap disc and no bog or vary little spot putty. I gota finish my 76 celica and help my bro with his xb fairmont, i also did our work ute a hz 1 tonner, under the front window wit the mig and mate did that look like frankenstein lol
Re: Help me weld pleeeeessssssssseeee
It come up pretty good.. thin stuff is a pain and with a welder with such harsh adjustment you'll find one to cold and the next to hot.. so you have to use the wire to control to get the nice weld..
But pretty good finish..
Owner of
Westy's Accessories
