alitis007
mazda fitted factory turbo timers to the series 8 rx7 and nissan fitted them to the 180sx, they are good if you wire them correctly! The earth wire needs to be connected to the handbrake wire so when its down the timer won't work (no earth/ground)
if you have ever seen how a turbo and exhaust glow it takes longer then 30 seconds to cool it down, even if your engine combustion temps reduce doesn't mean that the turbo has cooled. No turbo timer can size bearings and make seals hard and also potentially crack housing, i cracked 2 turbos on one my first cars (1984 nissan exa coupe) even tho i left it count down from a minute. On my toy i have an auto counting timer that starts off from 1 min but increases the longer i drive over 3,000rpm.
