Hey guys,
Currently designing drawers with integrated kitchen setup for the back of the patrol when I go camping. What have you guys done?
Would appreciate any photos etc
Thanks guys!
Hey guys,
Thanks guys!
Hi mate, I have moved your thread to Questions related to DIY projects
Toddie
Mid way threw mine.
http://www.nissanpatrol.com.au/forum...2013/03/66.jpg
Fridge will sit on top left, above a short draw for recovery gear and under that will be a pull out bench top / table, the on the right is the full depth food and groceries draw.
Owner of
Westy's Accessories
I'm gonna do a similar table slide but thinking aluminum u channel and slide a piece of ply into that.
this is a quick sketchup of what im thinking
A very hard wearing nylon called UHMW..
A 3mm thick bit on both sides and it slides like its in ice...
Owner of
Westy's Accessories
Wow I might look into that! Seems like a cheaper option!
That uhmw strip looks good westy. Where would I source that?
Pretty sure the father in-law got it from banner (good hardware store). Comes in a rod form to. Cut it with a jig saw or band saw.
Owner of
Westy's Accessories
Had a set back. The top sheet bowed a good 60mm. So its cut and ready to go, I've just had to wet it and try to reset the sheet s bit.
Shift work is hard to get stuff done around. But on days after Easter so should be able to smash it out.
Owner of
Westy's Accessories
The pull out table is a cool idea, and easy to use...
A&j
