Brand New SS 6" shocks making car bounce badly!
Well basically i installed 4" flexy coils and 6" suspension stuff monotube shocks then took the GQ for a test drive and was getting thrown out of my seat on a road that i usually never felt bumps on with my old shocks. What could be wrong? Im thinking the shocks may have been valved wrong. Any ideas?
The spring rate could be too high or in other words the springs are too stiff
Did you bleed the shocks, or just bolt them straight in?
Quote:
04OFF
If you feel the need to give it a go......
If you have access to remove someones elses towbar hitch, and depending on your shock type and size, put the lower end of the shock into where the hitch goes, lock that end of the shock to the towbar with the hitch pin, inserting pin through the shockie mounting hole (rubber in place)
Now you can use a long steel bar (or strong broom handle etc) through the other end , and you can get 2 or even 4 people on it, to push and pull the shock with much less effort.
DONT use the your own car while its jacked up/on stands, you may push it over.
You don't need you car on jack stands to remove to shocks.
