Control arms, pan hard rods and wheel alignments
Hi all
In the process of replacing the stock/weak original control arms. So far I've got a set of stronger trailing arms, but I'm having trouble trying to find stock length upper arms. I'll be fitting 2 inch springs, so my question is are the superior engineering upper arms suited to 2" lift a good option? I've left the trailing arms at stock length. Are the superior engineering panhards that are suited to 2" lift also a good investment? I don't want to buy anything adjustable as apparently they are illegal. Everyone seems to think that a 2" lift doesn't require any modifications apart from longer shocks, so I'm assuming that these superior arms are only minutely longer than stock?
Here's a link to the items I'm thinking about fitting:
http://www.superiorengineering.com.a...oducts_id=6497
http://www.superiorengineering.com.a...oducts_id=7295
http://www.superiorengineering.com.a...oducts_id=7304
Also, what do the guys do when they do a wheel alignment on the patrols? I cannot see any part that is adjustable.
Andy
I have never heard of adjustable panhard rods being illegal. That does not mean they are legal, but I would be very surprised if they weren't.
As for 6mm vs solid I think you would have a very very hard time bending either of those. I would think the solid one would be damn heavy!
And any way for a 2in lift I would not be bothering with adjustable panhards. I would get strengthened lower trailing arms, just leave the standard upper arms, fit castor correction bushes to your radius arms (front) and extend your brake lines and diff breathers.
