Oil/petrol smell coming into cabin
Hi all,
Since I bought my GQ at Christmas, I have been getting an burnt oil/fuel smell into the cabin... Even with the car off.
Today I decided to go problem solving so I pulled the glove box and center console out so that I could see the venting system and decided it wasn't from here.
I figured out that it was coming from the external air intake and not the recirculated air.
So I took off the windscreen wipers and then the grill that covers the air intake (behind the bonnet) thinking that something must have died in there. To no avail... Clean as a whistle!
Stuck my nose in the air intake area (behind the bonnet) and it smelt clean. Started the fan again and within 20-30 seconds the fumes started again.
Figured out that the smell was coming from the engine bay and that when the fans started up, it sucked air under the bonnet from the engine bay.
I then stuck my head deep down in the engine (near carby) and it smelt the same as what comes into the cabin.
So, the questions I have are:
- has anyone come across this before? If so, how was it fixed?
- should the smells from the engine be able to be sucked in through the air intake?
- could it simply be that the engine needs a shit hot clean?
- should I be looking at leaks once the engine is clean?
- could the carny be leaking petrol without showing any signs? Eg fumes
Any help would be greatly appreciated.
Cheers, Dave
Re: Oil/petrol smell coming into cabin
From what little I know, you shouldn't really get any smell coming through the vents, whether they are on recirculate or not. If its definitely a petrol smell, could be a loose spark plug, or fuel line.
Is there such a thing as RTI..... Repetitive Tapping Injury?????
What about a leaking rocker cover. That fixed my oil smell problem!
Sent from my iPad using Tapatalk HD
Quote:
Ducer
I see a spot for a bookie here somewhere. 3 say rocker cover, im going with oil/crap build up heating up... TBC!
Mines got a leaky rocker cover and I'm getting a burnt oil smell in the cab. Should be easy to visually check if your rocker cover is leaking.
FanTapstic!
Not sure how easy it comes loose. Mine has stayed tight since I tightened it a few weeks ago. I have degreased the area but there's still oil in behind the engine that I can clean out very well. I reckon that's where the smell is coming from. Heres a good test: when I degreased it, for a few days I could smell degreaser as well as oil fume so I reckon it's safe to say that's where the smell is coming from in my patrol.
FanTapstic!
