nipagu7
I think in a normal cooling system the coolant heats up over 100 degrees causeing water to become steam , creating pressure . coolants help transfer heat out thru the radiator a little faster but i think that is a byproduct of their main job , that is , stopping corrosian , which would otherwise build up and form an insulating layer between the water and radiator flutes and slowing heat transfer . In the long term corrosian would block the radiator as well as corrode thru it and the engine block and head . If you heat up fluid it must expand , but it may it may be minimal . Without water in the mix it might not gas ( steam ) off , thus negating the need to pressurise the system . But never use straight coolant , it is acidic and will eat thru your radiator and block. This evans coolant looks interesting .
