How to connect three auto LPG tanks
Hi Guys,
I have a Nissan Patrol with two LPG tanks.
Two tanks are connected with a hydrostatic tee valve the usual safe way it's suppose to be. This is the one used in mine.
http://www.amrgas.com/p_hydrostatic_tee_valves.html
I am wondering whether I can connect a third tank.
How do I do that?!
Is there an X type hydrostatic valve to use for that?
Any advice/suggestions appreciated.
Re: How to connect three auto LPG tanks
Hey mate. Had the same situation. But its a simple fix. All you need is a secound hydro T valve in the supply side of the current hydro valve.
Sent from my HTC One X using Tapatalk 2
Yeah mate. That's how I have it. I've actually got mine all individually switched, so I can choose exactly what tank to draw from.
From the sounds of that, there's one of 2 problems. Faulty solenoid, or still pressure in line. Try starting engine with, then turning gas off at supply point. If the engine turns off then its just because its holding pressure in lines while off. If not the valve might be broken. In which ide take to specialist...
Awesome. Glad it all worked out for u. :)
