How I repaired my sill damage (GQ)
On a camping trip over the weekend I dented my sill real bad and while in the process of building rock sliders this was a kick in the teeth. I decided to get on it right away and fix the problem. I bought some multi-purpose heavy duty bog (Selley's Plasti-Bond) from work some sanding gear and I was ready to go. This was the first time I have taken hammer to car panel let alone bogging painting etc..
http://img716.imageshack.us/img716/2012/img1040li.jpg
http://img339.imageshack.us/img339/6241/img1041yc.jpg
I started out with a big job ahead of me and first asked questions about bogging the whole way or fiberglassing then bogging but ol' mate ThreeDogs suggested a brilliant little idea, Rivet into the sill and pull the dent out to minimise bogging. This was step 1.
http://img826.imageshack.us/img826/6127/img1043k.jpg
After this I had to carefully straighten (belt) the step part of the sill and flatten it out. I then used a few more rivets to finish up pulling out the panel as much as I could. This worked an absolute treat and I can't thank TD enough!
http://img405.imageshack.us/img405/4835/img1045rb.jpg
After finishing pulling the sills out as much as I could I finished off the rivets then drilled them out leaving me with a whole heap of holes giving more strength to the bog from the extra adhesion.
http://img402.imageshack.us/img402/7480/img1046f.jpg
I mixed up my first batch of bog and went for it. The first coat was a starting point but I had a long way to go to bring it to my standard. So it was just bog sand bog sand etc until it started to take true shape and I was getting pretty impressed with it.
http://img502.imageshack.us/img502/2830/img1047qp.jpg
http://img194.imageshack.us/img194/6967/img1048yu.jpg
http://img171.imageshack.us/img171/162/img1049ze.jpg
I realised I had also bent the bottom of the door too so I grabbed a bit of timber and carefully brought it back to a nice straight line and this worked amazingly!
http://img515.imageshack.us/img515/9819/img1057d.jpg
So tonight being the 2nd night after denting the sill I'd say I have a few more to go but this is the detail I like to go to. This is as she sits now, it's almost done and ready to get the lines right and a final sand.
http://img43.imageshack.us/img43/6740/img1055us.jpg
http://img855.imageshack.us/img855/8946/img1054cf.jpg
http://img803.imageshack.us/img803/7247/img1053pl.jpg
http://img850.imageshack.us/img850/5516/img1051e.jpg
I plan on sanding back both sills once finished, 2x undercoat with Killrust Heavy Duty Primer then 3x Coats or black gloss Killrust and top it off with hopefully an automotive clear coat 2 or 3 coats. I will then checkerplate both sills and all 4 doors under the creased line in the panel on them to cover and proctect them, along with the dent in the passenger door. Don't think I won't keep you all updated! I hope this inspires others to fix their misshaps ;)
I have one a lot worse than that. Wanna fix it for me? Haha
I think its more of a cut out and replace job. Ill take a photo haha
I drilled the holes for the rivets in the lowest points of the dint and using my river gun it takes 2 pumps of the handle to finish the river off so I did 1 pump which left the tail on the rivet and just used pliers to DIRECTLY against the rivet, not on an angle or lever because it stretches the holes. I just keep moving along and it worked perfectly, but I didn't do as much as I probably could looking back on it. I then just finish the rivet off and drill it out
Quote:
Dales300exc
I would have if I ha the access to a mig but I didn't, I also wanted to test myself out as I hadn't done this before
Yeh mud that's how they do it in the states, there's a specific tool I saw on YouTube but this is the same principal, all credits too three dogs for this too
And yeh just worked along and went back over, I probably should have done more though, the more you can do with the rivets heaps less work later on
