Black deposit in intake of TB48DE
Hi all,
Over the last month or so, my 4.8 has been idling really rough to the point of stalling on occasion. Seems to be normal when driving at speed but for a significant lag if you put your foot down. It's on LPG and is the mixer type, not injected.
I suspected the air filter as I have not changed this in the 6 months I've owned this Patrol but when I took the old one out, I found a black, carbon like deposit covering everything on the intake manifold side of the filter. Running a finger over any of the internal surfaces would leave it black and clear finger prints in the deposit.
Obviously this isn't going to do the MAF sensor any favours and I will buy some cleaner and clean it up tomorrow but wondering if anyone had seen this type of thing before? A mechanic mate reckons it's probably oil from the PCV but I don't see a PCV connection upstream of where I'm seeing this stuff and the deposit is dry and powdery, almost like smoke damage.
Seems to have been happening for some time or due to an event prior to the last air filter change as the filter I took out was relatively free of the black deposit on its metal parts and the paper element looked pretty much the same as the new one.
Cheers!
Scott
Re: Black deposit in intake of TB48DE
Possible a stuffed gas converter. Take it to a gas specialist and have it checked.
The black could have been seals and the rough idle is possibly the engine flooding with gas?
Has gas mileage changed much or can you smell the gas?
Owner of
Westy's Accessories
Is ask around town at mechanics for a good gas repairman.
But I'd put my money on the converter or maybe the actual regulator on the tank Could be playing up.
A good system going over and a tune should see you straight.
Keep us tuned
Owner of
Westy's Accessories
Have any of the gas places suggested a tar filter on the gas system?
Quote:
beaST_01
What is a tar filter????
Some new cars on gas have a tar filter that gets changed every service, might be able to be retrofitted???
