1 Attachment(s)
Aluminium tool boxes touring setup
Hi guys
i have had an idea running through my head for a while and wanted to see if anyone has any major issues with it or has seen anyone else do anything similar...
At the moment i have a very heavy (300-400kg) ute canopy that is a rhs fram construction with aluminium sheeting for doors, the weight includes 4 liftoff legs and the roof top tent on top. Apart from the weight the major issue i have is that it is very tall, the top of the roof top tent sits about 300mm above the headboard. It is 1800 wide and 1800 long, leaving useable space at the end of the ute.
I am considering getting rid of it and buying 2 aluminium boxes 1200mm long x 500mm deep x 700mm high. Then bolting the roof top tent to the top of the tool boxes, fit out the passenger side with a water tank and kitchen, and the drivers side with tools, clothes and recovery gear. On long distance touring trips i can move the 2 boxes 500mm down the tray and have a row of jerry cans with 2 spares on top along the head board. Plus i can fit 4 900mm long space cases between the 2 aluminium boxes.
My major problem at this time with this design are that i have heard that over lots of corrugations these tool boxes tend to flex in the wind, ending up with them work hardening and tearing out the bolts that hold them down. I am also unsure as the wether they would be strong enough to hold the weight of a roof top tent over corrugations and serious 4wd.
Has anyone ever had a RTT mounted to 2 aluminium tool boxes or know of anyone that has?
I am currently thinking that i might bolt some unistrut into each of the back corners and across the roofs....hoping that this might give enough structural stability to maintain their integrity??? Plus it would be a good start to a shelving/storage system.
Any ideas/feedback would be greatly apreciated???
