the evil twin
Uuummmmm... agree wit the majority but just to clarify a few points...
VNT grub screw adjustment - will control spool up not boost pressure but helps reduce pressure spikes by slowing the spool up as it reduces the amount of angle the actuator can put on the vanes. Us patrollers are stuck with this adjustment option because unlike Skylines, Soarers, WRX's etc we can't easily remap the ECU when we mod other aspects of the engine. Too much adjustment will kill the spool so badly that yes, you won't appear to get max boost and you'll almost think you are in limp mode.
Dawes Valve - will primarily control max boost not spool up as it opens/closes at the set pressure. If you are "factory" and all you are worried about is boost spikes then this is all you need BUT may need to be tweaked to get the correct pressure as some of them out of the box will have too much/not enough spring pressure.
Needle valve - will primarily control spool up as it controls the rate of change of pressure to the actuator. If you have mod'd the exhaust or EGR or whatever and fitted a Dawes then this is very handy for setting up the manual spool rate that best suits your vehicle use.
CRD's seem to be a different animal to the Di's in that as mentioned above the Di's love the Dawes/Needle mods but the CRD's seem to go quite OK with just a minor tweak of the VNT. Dunno why, just the nature of the beast.
Having said the above obviously each item or adjustment will affect other parameters but as a side effect not a primary adjustment.
