alright guys here's the rebuild I did on my clutch booster. cost me less than 100 and works as good as new!
step 1:
remove everything off front of booster and undo everything inside the firewall that is connected to the booster. should be 4 nuts holding it in place.
here's what you get:
Attachment 23440
1 stuffed booster
step 2: put booster into vice and clamp it with the 4 studs Inside and the main shaft pointing DOWN. don't squeeze the crap out of it, just enough to hold it in place and not move.
Attachment 23441
here's the fun part...
step 3: get a piece of square bar about 400-500mm long. drill 2 holes in it to slip over 2 diagonal opposing studs, make sure you've removed the little rubber seal and washer with a screwdriver and remove the shaft that goes into the master cylinder.
Attachment 23442
now use it as a massive breaker bar ad PUSH!!! will take a bit of muscle!! you need to rotate the top half until the little gaps line up and you can seperate the 2. THE 2 HALVES ARE SPRING LOADED. TAKE CARE SEPERATING!
here's what you get
Attachment 23443
Attachment 23444
pretty much, from here just replace all the corresponding parts.
make sure everything is clean before you out it back together, and paint the outside if you wish!
here's some more pics if they help!
Attachment 23445
Attachment 23446
Attachment 23447
Attachment 23448
Attachment 23449
and finished!!
Attachment 23450
any questions feel free to ask! I'll try an remember what I did haha
cheers,
Kade
