DONT GO TO ARB. My dad got a dual battery system for his pajero installed by arb with two anderson plugs in the back. They did a shocking job, only ran one lot of wires to the back then piggy backed it when it got there. The dc-dc charger they installed incorrectly for the type of battery dad had, plus they put a horrible little fuse holder in that kept on melting. Dad went back to arb 3 or 4 times before he got sick of it and fixed it himself the lazy bugger.
Ideally if you have the time to learn and setup something yourself it will be far better and cheaper than what arb could ever do, plus you know how everything has bee run so you can fix it in the future.
I vote for the pirahnah model as its made of mill spec components and designed to operate at higher temperatures than the redarc in conjunction with a big heavy marine switch for cranking and winching. The down side off the top of my head is that i believe that the pirahnah doesnt actually have a solar regulator in it, just a feed in.
If you are interested in doing it yourself, then this book is an awesome resource to understand everything
http://www.caravanandmotorhomebooks....ravans_too.htm
No affiliations, just trying to share some of the stuff ive found from researching for my own truck :)
