I have purchased a snorkel from eBay ,cheap,was wondering has anyone else purchased one.How they went about the install.
It came as a full kit with templates and fittings just no instructions
Cheers Neil
Cheers Neil
You may struggle ,if template is not right, there are a few problems with the cheap snorkels.
not many shops will fit them, so good luck. Maybe a member close by who's fitted one
may be able to help
Use the Template but check everything before you cut. It is likely that the template may be slightly out so Measure twice. Set the Template up on the panel and then test fit the snorkel, it should be fairly obvious if they are not in line.
Be smart and it wont be that hard.
thanks for that,i havnt started drilling but everything seems to measure up ,the A pillar looks to be the part that is going to stump me ,they have given me 3 small bolts but nothing to attach them to on the A pillar.
see how i go
Neil
I recently put one of those on my mates Disco.
Template didnt line up the best for us. The inside part that connected to the filter didn't fit very snug on the Disco so double check that side of things. We had to silicone it shut as there were 2mm gaps and uneven moulding.
Take some photos for us if can so we can check it out.
Yeah templates never work done three now all different brands and run your own pipe off the bit aswell makes it slot easier
Still haven't started,I came across the safari fitting instruction off a mate,hopefully I will get to do it in the next couple of days
fitted snorkel this arvo,started at 330 and finshed at 6,was a little bit fidly but happy with the result
stoked though all up $42.50 for the snorkel and it looks identical to the safari
Well done, throw up some photos too mate!
i will give it a go ,i am a bit computer inpaired not sure how to do it yet
The time it took you ,tells me you didn't run into any problems.
need pics, when you do post press "go advanced"
I know Jack about pooters and if I can you can, have faith
Sheeesh computer impaired, folicly impared, need I go on
the safari instructions said it would take 100 minutes ,it probly took the most time removing the airbox and inner gaurd,i did take my time and measured 10 times to cut once and the only issue that i found was the elbow that attaches to the airbox ,but in the instructions from safari it tells you to use copious amounts of siker flex so that was alright to fill an uneven 2mm gap.
But over all im stoked
Cheers Neil
Came up good mate, job well done.
Looks good, what rims do you have?
they look different.
