Body lifts...how hard are they to put in?
Hey Guys,
My GQ has a 3" spring lift and I want to have a go at doing a 2" body lift. Has anyone done this themselves and if so how hard is it to do and what do I need to know to do it properly? Is it basically just a matter of undoing the bolts on the body mounts and jacking up the body until the lift blocks and new bolts go in? Just wondering if it's something that can be done at home or whether it should be a paid job for a pro?
Re: Body lifts...how hard are they to put in?
Just a thought with the low range gear, can you just pop the lever off the spline shaft and adjust it suit lift?
Also grab some old thin conveyor belt to re-fill engine gaps.
http://www.nissanpatrol.com.au/forum...2013/02/61.jpg
http://www.nissanpatrol.com.au/forum...2013/02/62.jpg
Owner of
Westy's Accessories
Quote:
MudRunnerTD
I have seen guys try and Bend it with mixed results.
Cutting a slot in the floor is simple and works well. I had to also slot the back of the boot to allow for it to make some room for the stick. Not that big a deal though
Yea I get you can bend them, I might try adjust mine.
Bloodyaussie
Is it ever worth doing 1 inch???
Just asking so dont hurt me!!!
I did.. and was enough for me. I'm now at a happy 3 inches.... In lift...
Owner of
Westy's Accessories
Anyway, yep easy as. A couple of points to watch for, as mentioned remove all rubber between chassis and body..
Secondly, and the biggest... Watch the brake lines from cab to chassis... They are a coil, but still can kink...
Also if you have rear stabilizer release you will need to remove the front bracket securing it to your chassis, to allow it to move up, its a solid cable so don't bother trying to bend it or move it...
You will also need to do longer brake lines from body to axles and also your rear brake bias will need an adapter plate now your getting that high, otherwise you will have no rear brakes..
Stock bolts are a M10 fine thread, 100mm long.
I went m12 fine thread, 120 long for my 1" lift, so you'll need 140mm long
Make sure you get zinc coated bolts..
Owner of
Westy's Accessories
Where did you get the kit from? Please ensure you are using high tensile 8.8 bolts..
