240V to 12 Volt converter
I'm in need of a 240v to 12v converter.
My camper is all set up for 12 volts....Lights
It still has the normal 240 volt plug on the side of the camper which has a couple of power points in the camper but my plan would be as follows..
When camping at caravan parks with power I want to plug into the 240 volt power source at the camp site to run power into the camper then using one of the power points in the camper get a converter and plug the 12v socket of the camper into the power point for lights and music and chargers, etc.
All of the Ebay crappy ones can only supply maximum 500 milliamperes which is about 0.5 amps.
I need on average 2amps would prefer up to 5 just in case.
I found this one...
http://www.ebay.com.au/itm/240V-Powe...ht_3058wt_1139
• Input voltage: 240VAC
• Output voltage: 12VDC
• Output current: 7.5A
• Dimensions: 157(L) x 90(W) x 57(H)mm
Can anyone confirm that this will work for me or does anyone use these devices and can comment?
Appreciate any feedback!
http://www.nissanpatrol.com.au/forum...2012/08/83.jpg
