happygtu
Hi James,
I wouldn't be looking at changing the motor to anything else but the same 2.8 that you have already.
Anything else is going to cost more than you have already been quoted, and if dollars are tight, it doesn't make any sense.
To go to a 3L Patrol, you would end up having to change heaps of bits, and then you would still want to make sure that you pick up one of the later 2005 -2006 motors, and not just any 3L, or even the CRD.Probably cost in the vicinity of $15K with the motor, gearbox, computer, wiring, radiator, etc
Worst case with the 2.8 you have full rebuild is 6K.
If you get your mechanic to do the head, $3.5K, but maybe try to ask for a better deal, or if you are on really good terms, he may let you do some bits yourself to savea bit.
Best case is that you search around - others have mentioned picking up new genuine heads for the 2.8 for $1K, and if you and a couple of mates are handy, you can get away with the repair for less than $1.5K with new gaskets and head bolts, etc, and you are back on the road.
Mic
