Hay I have an 08 st with a factory bull bar I was wondering if I need a special plate to mount a winch to and would a warn 10000 pound witch is 610mm fit easily I have 625mm in between the rails thanks everyone
Is It a winch bar?????????
http://i1258.photobucket.com/albums/...8/7e79d350.jpgLooking in through the front
Looks winch compatible to me
That's a winch compatible bar bang one on
Thought so but do I need another plate to go in to fit the winch
what do you mean you need another plate? where abouts are you talking about?
On my hilux factory bar I needed to bolt the winch to a special plate witch I wasn't told about until I went to fit the winch then the plate was bolted to the bar
Not as far as im aware all the necessary holes are there to mount the winch.
Cool hope so
