Hay Team.
Here is some pics of my rear storage system. Nocked it up myself, helps being a chippy. :)
It has two storage box for draws, and a third space which houses two rescue tracks at this stage, will make that into a box soon. The forward section houses a 90L water blader which is plubed into a tap at the rear doors, also has storage just behind rear seats that as you can see holds my axe, as well as two sections to hold those knick knack bits in easy reach. Has a battery box mounted on it with a deep cycle batter inside, this is going to be wired into dual battery system making it a tri battery system, plenty of power for those looooooong trips away.
