Knocking/rattling in the front end.
Hey all i've recently noticed a knocking/rattling noise in the front of the gq. Its sounds like its coming from the drivers side under the footwell or the door. I've been under it and shaken all the suspension components but nothing moves. You only hear it hitting bumps etc on the rd. If its perfectly flat you hear nothing. I do have a leaking hub seal which i will be replacing once the kit turns up, could it be something inside of there.
I'm gona pull the door skin of as well and see if there is something loose inside the door.
What else should i look for.
