"How to" GU Bonnet Scoop Removal - a question about the rubber shroud.
Hi All,
Just bought a big mouth scoop to replace my standard GU scoop with 6 x 10mm nuts to remove and replace easy as right? It is, except removing the rubber shroud with a steel retaining bracket that is clipped on with plastic clips under the bonnet.
Before I totally make a mess of it, I thought I would ask if anyone has experience taking it off first. I checked the Y61 Manual section and no luck, searched the forums and tried Professor Google.
I have no idea how to access the clips and so on; they appear hidden away.
"How to" GU Bonnet Scoop Removal a question about the rubber shroud
We recently just bought a 1933 Victoria Convertible, and it has a set of matching luggage in the trunk. How can I find out more information about this luggage/suitcases?
