3 Attachment(s)
Tralier mod time I think....
Since we haven't got the room for a nice camper trailer I thought to do some mods to my trailer I have just so its more camper friendly for me.
The trailer I have currently is,
- 7' x 4' with 18" high sides.
- Well made from a local trailer guy.
- Stock trailer suspension, slipper type
- Stock 5 stud holden pattern wheels.
- two rear/ side mounted jerry can holders
- LED lights all round. :)
First thing I want to do is lengthen the draw bar and set it back further than where it is now. Almost at the front of the trailer.
The draw bar now is currently 1200mm from the front of the trailer to the centre of the tow ball.
What is a good length to have this longer at? Its currently using 50 x 75 RHS I think its called for the draw bar. I will cut it off and want to re-weld further down the trailer plus making the draw bar longer so I can fit a nice big box on it, to fit my 80L fridge and battery box. OR a box big enough to fit a battery box and other camping gear , then the fridge goes in the trailer....
Second is to scrap the suspension on it and get something better and higher so I can change the hubs to six stud and put some 31's under it. I don't need or want independent suspension too. There is shops that sell complete spring setups that i can just buy and weld on isn't there?
Third is to give the girl a sandblast and new paint job.
I eventually want to fit a water tank under it too maybe...
So I want to do the first, first. I have all the tools but I only have an ARC welder. One of the Blue CIG ones with the 2.5mm and 3.2mm switch. I'm a pretty good welder, not great but I can weld....
I kind of thought i might need a mig but I dunno.
Suggest away.
Thanks.
The longer draw bar the better for reversing. Mine on my work trailer is 1800 from the front to the tow ball and its a pleasure to reverse also you can make a platform or put a larger toolbox on there for storage
Just tap it in just tappy tappy tappy
Hey mate, mine is very similar to what you have planned already, if you want me to take to snaps I could upload them for u this arvo?
I got my trailer from an RFS auction and it's solid, plus it fit 31's on straight away
Tappin
Re: Tralier mod time I think....
Your sounding similar to my olds to.
As above go a 750-1000kg spring rate, set to the height you want (dont forget to deduct the tyre increase), and add a couple of shocks. It makes so much difference its not funny...
And the water tank.. great idea.. mine is forward of the axle and is 70ltrs.
My only grip is the tow ball weight.. the axle really needs to move forward 50mm...
So imo, do the tank (rough mount), toolbox, spare tyre (if mounting up front) and draw bar, balance the trailer so you have ~30-50kg on the ball when tank is empty and you should be around the 70-80kg once tank is full.. once happy with axle position, weld it on...
125x50x3mm shs is the pick for the draw bar if mounting box and tyre up front.
And also go an electric brake system with override/ hand brake on the hitch... Imo a nice little feature to have. I wish I did...
Also stick will be fine. 16tc low hydrogen would be the pick of the rods.
Owner of
Westy's Accessories
Quote:
threedogs
1800mm draw bar , Alco greasable off road springs , Triple draw bar. O'brien off road coupling , 6 stud hubs, solid axle and electric brakes, Keep all receipts, is your current trailer reg'd or have id plate?? Turn it up side down and cut everything off and build it that way. Believe it or not there is a formula on draw bar length, you might be better selling this trailer and getting a 7x5 you'll thank yourself, I've built and modded a 6x4 and 2 hilux tub trailers plus countless repairs to trailers, PM if you require a hand , new saftey chain needs to be rated as well as shackles
If you have no proof of purchase for your trailer forget it, I still have receipts for steel for mine as person forgot to stamp "sighted" at rego branch
My bad thought it was 6x4,,,,,,,,,,,,,,, 7x4 is OK as can box in sides for extra storage,battery box etc
A swing up wheel 250mm wheel as easier to move, pre weld any tabs on draw bar for box mounts plus extra for future mods. Drop over and check mine out
I can run 33's but run 285s as not as wide, 30psi could sit on 140 with this in tow,
That floor always make me dribble a little..
I'll stick some photos up of mine so you got some idea of different designs.
Here is my rig in the drive way
http://www.nissanpatrol.com.au/forum...2013/02/48.jpg
Nice and level, but only because if airbags in the rear..
Owner of
Westy's Accessories
Sorry mate. We got a bit carried away hay.. arc/ stick welder is fine, as I mentioned though 16tc's are the better option.
If your going to be putting a bit of load on it then a spring upgrade and shocks are a good option.
A few mates over to turn it over and move it.. Till be easy...:p
Owner of
Westy's Accessories
mudski
Just going through these comments again and come to think of it, I have to really watch out I don't make the draw bar too long ad then I will be putting too much weight up front. Unfortunately I can reposition the axles as the guards are already there. Maybe a water tank in the rear might be better to even things up a bit.
Yes that is a option.
Owner of
Westy's Accessories
