Are bash gaurds easy to make for a gq patrol
If so can people give me info so I can make some
what and where do you want them?
Under the front of me car to protect my sump n at the rear to protect the fuel tank
Big ask. Only seen one fuel tank guard. And it was the whole rear bar setup. Looked like it weighed a ton to..
May I ask why you want Fuel tank guarding??
I wouldn't see the need personally, each to there own though .
Has the gq got nothing? Even a gu has a flimsy factory guard that I think would be sufficient in most cases.
Have a look at a gu one and see if you can modify it perhaps ?
Are you trying to protect the rear fuel tank or the one under the drivers seat? Assuming your petrol.
I have never seen a GQ with a rear tank that did not have a factory guard? Ring a wrecker and you should grab one cheap mate.
Check out the Harris Hard Nose for frontal protection, he has recently done a limited run and he may have some left. Check the vendors section mate. Good bit of kit.
I think there is a fuel tank guard and a flimsy one at the front
