Hi,
From my screen name you can no doubt tell where I am from originally :-)
I have a 92 Patrol LWB Wagon with an aftermarket DTS Turbo kit added by a previous Owner.
I have owned it since 2008 but do not get a chance to use it much as I work all over the planet and don't get home much.
I just had 5 weeks at home and probably did 4 k km's as I was moving houses and it is a good towing vehicle.
It has beefed up suspension, a lift kit and is currently on Kuhmo 35 x 12.5 x 15" rubber.
It runs very well and always starts like it was only just stopped even after sitting in my garage for 3 yrs it flashed up immediately it blows no smoke and burns no oil.
I have no idea as to the service history but someone has had the sump off ( and put it back on) as the gasket is showing and there is non Nissan goo visible in a few spots.
I got it with some Maxi Crawlers on it which proved to be a handful when driving on the road which until recently was always a big part of its function when I was home and changed the wheels complete.
I drive mostly on the road and beach as I am a keen fisherman and use both a surf caster and torpedo so I it great to hum all the gear associated with the Torpedo.
It is the second one I have had, the first was an '86 Trayback model with an SD33 Engine purchased from the Dalrymple Shire Council west of TSV and used extensively for a top end tour in 91/92.
