Yeah I think my Tap was labelled wrong.
It went straight in and didn't touch anything.
Do I need to shorten?
So I've jumped the gun and wired everything up bar the front switches on the grille for the high mount.
If I run a single cable (or just run two) from the isolator in the cab and then splice off to both switches (in and out) on the grille to both the in/out wires right near the solenoid surely that is ok?
Edit. Sorry just read your post again. Yes it will work but you already have a wire you can use at the front.
Take positive power from the LED light straight to those 2 switches in series. That power is isolated via the inside isolator switch. They just need a 12v supply they can send to the Solenoid for switching. Have another look at that drawing I did bud.
