Made the mount bracket for the Quicktifier unit, hooked it up, no sparks or flames, idle voltage went up 0.3V, so good result. Starting on the rear wiring mess tomorrow, or Monday, still have to sort out a couple of items now without power since my clean-up, and finalise the wiring looms under into corrugated protection. Mounted the wiper washer bottle after first extending the piddly wiring looms to the little pumps - added 300mm to each cable so they can be connected whilst the washer bottle is out of position instead of having to grow spider fingers to plug them in - worthwhile mod. I believe.Then onto the lighting set-up to deliver the 28V to all the LED's as previous.
