11 Attachment(s)
Bodywork - choosing colors
So, by now the bodywork is done and the paint job is halfway though, but I'd rather post the complete work for specific parts so one can see the evolution. Also, at some point I was able to buy a donor junkyard car. Rusted to death but with several hard or impossible to find bits and pieces that I can use on mine.
The actual choosing of the colors was made after bodywork was complete, but again, since I am going to show parts evolution from start to finish, the chosen color will be there, so let's start with the color.
Since beginning of the restoration I felt in love with the 2020 GM Onix called Seeker Blue:
Attachment 84570
One day, on the drive-through to take my COVID jab, the car in front of me was a 2021 Fiat Toro in Jazz Blue:
Attachment 84571
Indecision had been planted! Also, for the "yellowish gray" part of the car, I was in doubt for a very light gold/beige or a bit more presence beige. So I ordered small samples to be mixed at the local paint shop.
Attachment 84572 Attachment 84573
Left to right we have Fiat Jazz Blue, Toyota Aurora Beige, GM Seeker Blue, Honda Shoreline Beige.
Attachment 84574
I feel it very hard to realize the tone of a color looking into a small paint card, so I decided to test the samples using the barn doors of the parts car. Gave them a good wash, some very light and uncompromising sanding and gave them a go. I combined darker blue with darker beige (Jazz/Aurora), not so dark blue with lighter beige (Seeker/Shoreline):
Attachment 84575
Attachment 84576
Both combinations came out stunning!
Attachment 84577 Attachment 84578
Attachment 84579
Attachment 84580
And the verdict: I stood with the original pick, GM Seeker Blue. I am glad I took the time to do the comparison, though. I would possibly have second thoughts when looking at that Jazz Blue on a car on the road. Also, my end product is a tidy more dark then the Seeker Blue in the tests, for the reason the test doors were white, while my real car had a light blue primer applied. That enhanced the final color perception a bit.
13 Attachment(s)
Bodywork and Paint - Roof
The roof on my Patrol had at some point a roof-rack, but not the type that goes on the rain gutters, but rather, the one where the roof is drilled. Rack was no longer there, but the 8 holes were... Also, the back left corner was dented towards the inside of the trunk, most possibly due to carrying too much weight on the roof, or maybe due to someone standing on top of it.
First, I took all the roof inside parts apart. The roof lining is completely stained of iron ore dust. I saved it for now, to be used as a template for a new one when the time comes.
Attachment 84581
From the inside the roof had surprisingly nothing to deaden the sheet metal sound other then very few patches of cotton/wool blanket. Tapping on the roof would make drum-like noises.
Attachment 84582
Here the roof dent had been roughly beaten back in place and the holes were welded shut. The roof panel was later softly beaten to a better finish.
Attachment 84584 Attachment 84585
Some more gently beating, light coat of bondo, lots of sanding and some protection primer.
Attachment 84586
Attachment 84587
Attachment 84588
All the parts are being primed with a multifill primer tinted with blue paint for the final sanding phase. Here the roof is ready for final paint and can be seen in such light blue primer.
Attachment 84589
After the bodywork was complete, we used SILOC 44 rubberized PU adhesive to fill the gap between the roof sheet metal and the roof cross-member supports I don't have a good picture of it now, but the same was done on the hood/bonnet and for that I have pictures that I will post here later. Now, tapping at the roof makes a solid thud. Very good already but proper sound deadening will be addressed at reassembly.
Attachment 84583
And the final result after 6 layers of Seeker Blue paint and 4 layers of clearcoat:
Attachment 84590
Attachment 84591
Attachment 84593
Attachment 84592
22 Attachment(s)
Bodywork and Paint - Hood/Bonnet
The bonnet under-structure was broken in a couple of places and poorly stick welded. it also had some dents on the front lip.
Attachment 84594
My friend grinded that out and mig welded it back. Even so, he admitted that it was not looking much better then it was before, for the sheet metal being very thin. Also, there was nothing else gluing the sheet metal to the under-structure anymore, so I redid the gluing with SILOC 44 rubberized PU adhesive, same mentioned in the previous post. Instead of putting glue just on the pockets available on the under-structure, I chose to put it on 100% of the structure. Tapping the bonnet now gives you a solid thud. Will probably do more appropriate sound deadening when the time comes.
Attachment 84595
Here you can see some of the mig welding that my friend was upset with the appearance. I have also later regretted myself for not cleaning up the excess glue right after application...
Attachment 84596
I bought myself a 120psi / 130L /5 cfm second hand compressor and a orbital sander and got to work.
Attachment 84599
Attachment 84597
That compressor ended up being insufficient for the task. I did some more research and found out that at least 10 cfm was needed for the orbital sander. After a couple of weeks monitoring local classifieds for a deal, with people asking almost the price of a new unit for their used ones, I figured it was a better idea to bite the bullet and get a new one.
Attachment 84600
Work then started to move faster.
Attachment 84598
Attachment 84601
My friend noticed some bondo spots on the front lip and some other parts and decided to bring it to bare metal and do some panel beating. That was quick work for a flap disc on a grinder.
Attachment 84602
After some filler primer and lots of sanding we got it to this point.
Attachment 84603
And after full priming the top side of it.
Attachment 84604
Back to the underside, it was being a pain in the butt of a job to remove the excess rubberized glue, so I decided to wire wheel it and then sand out the wire marks.
Attachment 84605
Attachment 84606
Attachment 84607
And right before we moved into the next primer, my friend decided to give his welds some better finish, so he grinded them down some and then primed it all. The bonnet was now in pre-paint stage.
Attachment 84609
Attachment 84608
Attachment 84610
Then came paint day, and after 6 layers of Seeker blue and 4 layers of clear coat, it was almost impossible to take a picture of the full bonnet showing its color such shiny it was. The pictures were reflecting the walls and not showing the blue in its entirety.
Attachment 84615
Attachment 84614
Attachment 84613 Attachment 84612
Attachment 84611
