I won't say you guys are wrong but I will say my question is still un-answered and you guys are talking more about the affect of temperature to oil viscosity rather than how oil temp affacts water
go get a Temp gun, go check the oil temp in your car, and the water temp after its been parked all night
then run the car, say 2 or 3 hours, then check the temps again.........
"will you look at that.. BOTH are now hot"
if you have a radiator to help disapate the water temp, pray tell us why a radiator for the oil will not work.........
well, if we are not wrong - but obviously not correct, according to you
perhaps you would care to enlighten us on how and where we are NOT right?
you obviously know the answer
maybe spill the bean for us that are not wrong............ and then we will know the secret as well
Plenty of "oil coolers" have been fitted to Project cars,4x4 over the years to get the water temp down.
It should of been the first thing I did on my 350 4x4.
Miss matched engine body configurations are the worse to sort as they are not meant to be.
Anything that helps the oil do its job and maintain pressure has to be good for the motor,
bonus if coolant temps are down as well, I also used a product called wetter water,
As far as I can see any affect is going to come from the oil cooler, it is the only part where coolant and oil need each other.
If the oil cooler is gunked up, which many are it isnt going to work effectivly, so less oil cooling, more oil temp. Oil coolers inability to keep up so the coolant gets hotter and so on.
You should fit an oil cooler simply to cool the oil. It is not a solve for cooling system issues. But installing one is beneficial to both the oil and coolant systems.
In doing so this takes some load off the cooling system. This also wont make it run cooler but will help to stabilise temps. By stabilised I mean the gauge shouldn't move much from normal operating temp.
Just read a few articles on it and not one says its a bad thing (except the need for more oil) and all recommend it for any car they may experience more than normal loads.
Some say it helps with overall temps while others just say it is only for the good of the oil and wear and tear of the engine.
I might see how much cash I have next month (probably none) and look into doing this mod.
Might tie it in with doing the radiator clean.
Sort of agree with Roofy why are you having overheating problems , fresh motor new radiator.
I can see benefits if doing some comp style driving but you dont get that in the high country or Tallarook.
But temps will climb on steep long drives especially in low low
If you're doing it to be more efficient, so temps are a bit more consistant then yeah Its not that $$$$
for a decent oil cooler. TBO this should of been the first thing to do on my other 4x4 might of saved a bit of heart break
