Looking good.
I'm always keen!! I've got Sunday free if that works.
Looking good.
We are heading up Sunday morning Rossco, probably around 11ish if you want to tag along? We won't be doing anything extreme, just want to test the big girl out.
Yeah sounds good I'll pop out for a bit. Kinglake is pretty damn close from here.
Update
Tonight I solved a few issues that I've had from the start. I was having a charging issue, after a bit of fiddling I found out I had put the alternator earth to the charging post and left the battery charge wire unhooked.
I swapped those over and that solved my charging issue.
For some reason, fixing that turned off the battery, brake and air filter lights from my dash. Previously they were stuck on.
I also managed to get the tacho working. It was pretty simple really, just a bit fiddly.
For those that are curious:
I started by swapping the tacho component from my diesel dash into my petrol dash.
Next thing was the black plug on the back of the speedo. You can see here in this picture the yellow/black and pink/black wires. Originally the pink and black wire is just an empty, pinless slot. I pinched a pin from another plug and put it into that slot.
Attachment 50528
After that it's a simple as wiring the black/yellow to the blue wire on the RPM sender and the pink/black to the green. I found a plug that matched up perfectly to keep it looking factory.
Attachment 50529
Complete working dash and tacho.
Attachment 50469
Today I tested her out in the bush for the first time. I'm happy to say that apart from my brakes failing a couple of times (sorted now) everything went smoothly.
A few mates and I met up with Rossco at Kinglake, it was a fun day and it's always good to put a face to a name.
Few pics
Attachment 50530
Attachment 50531
Attachment 50533
Attachment 50532
I also managed to test out the door seals..
Attachment 50534 Attachment 50536
https://www.youtube.com/watch?v=OBwJGKD-sv8
https://www.youtube.com/watch?v=Tf_-mVLo-Hg
Cheers guys, had great day. I've got one good photo of that big bog hole, ill chuck it up tommorow.
Good vids that dts turbo does sound good . . .
Looking forward to seeing the pics Rossco. The carpets still drying out...
Hahah, good to see you've got the NP.com.au stickers on! Nice work!
nice one both those trucks sound awesome
The stickers look great. I'll have to get another for the rear window.
Thanks gubigfish, sure sounds better than the TB!
