Wow! That's pretty average.
Regardless of its lopsidedness, it still isn't a great fit.....even on the "good side".
They should definitely be doing something about that.
Yea fitted my self but it's not rocket science. I'll have to give them another call because every time I look at it I notice it first
you reckon its had a smash?
everything looks pretty good under the bar all the rails are the same height and length
Not so much a smash, but the car looks like it has sustained a "love" tap at the front, just the plastics under the lights, the RH headlight/indicator lamp is pushed back and up, the RH guard looks a little bent in this area also.
Your head lights body/s will most likley be slightly cracked, or your radiator support panel where the lights mount may be pushed/bent a little.
None of this means a huge impact, but id say the previous bar has copped a nudge and moved back into the front of the car a little.
Im not saying the Tigerz bar is OK and its the car, but looking at how your nissan alloy bar sat under the flare before hand, perhaps something may be not quite 100% right with the car side of things ?
http://i83.photobucket.com/albums/j2...101_180516.jpg
My Tigerz basket is now fitted, very happy with it actually.......
http://i83.photobucket.com/albums/j3...ack1Medium.jpg
http://i83.photobucket.com/albums/j3...ack2Medium.jpg
http://i83.photobucket.com/albums/j3...ack3Medium.jpg
As i do a lot of beach work, I replaced all the bolts/washers with stainless, i also dumped the spring washers, and went for nylock nuts, i worked out i could run 5 mm shorter bolts up top, then i would not have any thread hanging down, as this bit could perhaps catch your arm on when washing the roof, and was not needed anyway.
Time will tell if this was a mistake, or ive saved some money, at the moment "im" the only thing thats been on it, (walking around up there), but appears to be more than strong enough for my needs, and overall great value, its so light its fantastic. :D
Looks good on the plastic fantastic (white) GU bud..... Did you go steel or alloy?
