drove it to work.
drove it to work.
engine oil and filters.
air filter
sway bar d bushes
inner axle seal
repack bearings
seal rear pinon
rotate tyres
front pads
Worked out my trailer plug is playing up , blinkers are barely visible ,brakes are non existent but tail lights are good .
Cleaned it out and gave it a quick wash :)
Scratched the body work on a track that mustn't have been used in 5 years. It's at the point where polishing achieves very little.
Thought about it as I pondered over the wounds I encountered from putting the flanged inlet elbow back on the CRD turbo with alternator still in place-try it out!!!
Also installed second EGR plate (inlet manifold) both ends blocked now, and put all back together after discovering that my turbo comp wheel thrust bearing was shot. New turbo and 3"ducting on the mod list (what an excuse for an upgrade)...
