Are you lost or just really dont know what you want?
If you can answer this it will make things easier. What do you want to achieve with upgrades?
When winnie got his it was making 82kw
I can't remember what the first dyno I got was... I think it was 76 or something, that 82 was after the new turbo and cooler but before the tune.
To be honest I'm lost because I don't know what I want.
in the interim i want more power for towing the camper on long trips. I want more power for off road use and for general onroad driving and of course the wank factor of just having more power. Not going to lie on that last point.
Leah's commodore is coming close to its death. I have "long" term plans of getting Leah a nice auto 4wd for our family trips and my gq will eventually simply be a fun weekend car to dip into more challenging things.
You should be pretty happy with those numbers out of your little turbo mate. Small second hand turbo. It's doing pretty well. What is Boost set at now?
There is a very good Pump guy not far from you AB and he will put a 12mm plunger and rebuild your pump for under $2k. Just down the road.
Yeah he is a guy that sets up a lot of Competition stuff down this way. Low key but highly recommended to me. You can spend soooo much money on Pump mods, mild to wild. This guy was going to do my pup rebuild on the GUIV when I was chasing that fuel problem a year or so ago. Was weeks away from spending the money on a rebuild when I found the split fuel line causing my trouble. Lol
Just picked up some mesh and paint for the grille to cover up my hacking...lol
hey AB if I was to use a smaller IC would the pipes fit down the side of the radiator or in a spot where no cutting is involved??
Smaller pipe would be a lot easier mate as you can run the hot side directly to the turbo running past the alternator and in general a lot easier.
Unless you wanted to run the pipes underneath the body then up your going to have to cut in unfortunately.
Thought I would throw this pic up before I bolt everything back on.
Took everything apart today, siliconed up everything just incase and re tightened all clamps. Pita but peace of mind when in deep water.
Stay tuned for my awesome new grille...lol...just drying in the sun!!!
Goodbye crappy nissan clips, hello screw ins!!!
Man decorating!!!
I AM DONE!!!!
black is the new grey!!
Tried to use thin mesh to not restrict air flow, ill see how it goes!!!
About bloody time, now go and log some pyros!
To nissan badge or to not, that is the question??
Post a photo with the badge. I reckon it looks awesome.
Looks bloody good! Would look good with badge but dont forget its going yo get tight with a high mount.
Hmmm.... High mount.... hmmm !!!!!!
Which badge you got AB?
Did someone mention high mount somewhere? . . .
Yeah slowly working on mine.
Pine ridge rd has been closed for a while now. Shame used to be a good track, but got seriously chopped up after the fires, last time I went up was pretty rough.
Just picked up my bullbar ab.... everyone thinks that I am nuts swapping with you!!!
Blasted and primed ready for paint.
Attachment 48633
Your not spraying my one though are you??
