PeeBee
Use the 5v output plug. The 19v is more suited to laptops and camera batteries I believe.
OK, correction to previous post. I unpacked my battery bank and found a factory supplied USB to Iphone mini cable. I plugged this into the iphone, tried all 3 jacks, nothing. I then pushed the small black button between the 12v/5a output plug and the battery jumped plugs - bingo, turned the charge 'on' to the phone. so happily charging the iphone now.. Can't find any instructions with mine, but being a typical engineer, probably thru them out without reading! I suspect the standard iphoe cable will work with this device as well.
Regards charge capacity, mine sits at 4 out of 5 stars on the side. When charging from cig lighter the 5th light blinks. I can start a V8 petrol engine maybe 6 times before it needs a recharge. recommendation is to keep it topped up though from personal experience.
