mate if you stuff that up well ,anyway itll take you 10minutes to hook up
top hose to rockercover bottom hose to pvc pipe just after the m.a.f
Well I took the intercooler off and cleaned it with a 50/50 mix of diesel and petrol on a paint brush and blew it dry with the compressor. Inside is spic but the source of the oil appears to be coming from around the injectors so am doing more homework. Cleaned up the top of the block while it was exposed and will keep you posted with what I learn. Open to suggestions too...
Have ordered the ProVent 200 catch can and if we leave the job to the next workshop I shall invest in the valves and gauges and make the project worth our effort.
And Roofy, me thinks that object under the bonnet of your new rig that we couldn't identify at Neurum Creek - may be the catch can... what say you?
Thanks heaps guys.
Attachment 22183no that wasnt it the one with blue hoses is
So let me know when you do know what it is cause I am still curious. Thanks for the pic too, I can work with that. Cheers Roofy.
Taslucas, this is what the sticker looked like before the new windscreen went in.
Ok no worries, ill see what i can do:)
What object are you guys speaking of?
Its a vacuum tank. It holds the vacuum so you can apply the brakes many times and it is still easy. Its kinda like an accumulator but for vacuum.
